adupredeboulois
µPSD 3334-DV : Clock signal on an output pin ?
  • June 19, 2005
  • 710 views
Posted on June 19, 2005 at 07:44
adupredeboulois
Posted on May 17, 2011 at 12:07
I work with the µPSD 3334-DV.
I would like to know if it is possible to make a clock signal as an output.
For example, I would be pleased to make as an output the signal PCA0CLK
Thank You very much for the answer I will catch on that forum.
Alexis
rk1
hi,
you cannot directly route PCA#CLK to an output. but you can use the TCM# to i.e. toggle a pin according to PCA#CLK.
if you really need a ''fast'' clock-output, you can route the _ale-signal to an output-pin in the PLD.
(but then you should not use idle-mode/power-down-mode/reduced-frequency-mode, because this also stops/reduces the _ale.)
