anickol
Sep 8, 2010 3:11 PM UTC
AWU - what's wrong ?
Posted on September 08, 2010 at 17:11
    anickol
    anickolAuthor
    May 17, 2011 1:10 PM UTC
    Posted on May 17, 2011 at 15:10
    brazov22
    there is an option bit CKAWUSEL (see datasheet) to select awu clock source.
    brazov
    brazov22
    Ok, just read in the AWU interrupt routine the AWU_CSR register to clear the AWU interrupt. After HALT instruction, AWU generates an interrupt after a certain time, according value you set in AWU configuration registers, then exting from HALT micro jumps on AWU interrupt routine. Try it will work.
    brazov2
