y2399
Mar 14, 2006 6:15 AM UTC
AST7 look up table example
Posted on March 14, 2006 at 07:15
y2399
y2399Author
Mar 14, 2006 3:50 AM UTC
Posted on March 14, 2006 at 04:50
Hi all, and thanks for reading this post,
I'm looking for a syntax example for a 256 value look up table in ST7 assembler. Has someone ever done this ?
Thanks in advance for your help
Akotronic
fggnrc
Mar 14, 2006 5:51 AM UTC
Posted on March 14, 2006 at 06:51
Akotronic,
the ASM lookup table implementation depends on the size of each element.
As an example, here is the code that computes a power of 2.
; This is the lookup table
PowersOf2 BYTE $01,$02,$04,$08,$10,$20,$40,$80
; This is the code to access the lookup table
; NOTICE: X holds the exponent e.g. X=3 means 2^3
LD A,(PowersOf2,X)
If each element needs more bytes (I mean more than one), you have to split the data in more tables - the quickiest way for the ST7 - or do some address computation.
BTW, see the output file of a C assembler that implements a lookup table, you'll find some interesting hints...
Bye
EtaPhi
y2399
y2399Author
Hi EtaPhi and others,
In my case, I need only one byte for each element, so your exampe is ok for me.
Thanks very much for your answer.
Akotronic
