sjayapal
Mar 17, 2006 4:48 AM UTC
assembly code for a function with passing param and return value
Posted on March 17, 2006 at 05:48
sjayapal
sjayapalAuthor
Mar 16, 2006 7:54 AM UTC
Posted on March 16, 2006 at 08:54
Micro used: ST7FL35
Compiler and Assembler used: Cosmic
Memory Model used: MODMM
Does anyone have a sample assembly code for writing a function with 2 passing parameters and with a return value and made as global so that it could be called in one other file ????
Thanks,
Suganya
[ This message was edited by: Suganya on 16-03-2006 14:46 ]
luca239955_st
Mar 16, 2006 8:58 AM UTC
Posted on March 16, 2006 at 09:58
You can write a sample function in C, see the asm produced by the compiler for that, and go on from there.
Regards,
Luca
sjayapal
sjayapalAuthor
Mar 16, 2006 9:44 AM UTC
Posted on March 16, 2006 at 10:44
Luca,
As suggested i wrote a sample C code and tried using the asm code in my assembly file but i get the following error in it.
symbol _Check_Sample_Assembly$L not defined (Debug\timer.o Debug\cstartup.o )
I have attached my project, kindly let me know how to write a assembly routine to pass arguments when the memory model is modmm ????
Regards,
Suganya.
[ This message was edited by: Suganya on 16-03-2006 15:17 ]
________________
Attachments :
Luca.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Ct&d=%2Fa%2F0X0000000bWZ%2FNf5lfaZ03PldZnGliXqaNQC2dsjwAWTv6xBGNFcvS18&asPdf=false
sjayapal
sjayapalAuthor
Mar 17, 2006 1:39 AM UTC
Posted on March 17, 2006 at 02:39
Can anyone give a help on this !
Thanks in advance.
Suganya
sjayapal
sjayapalAuthor
I have analysed that shared sections ($L) are not getting created for the assembly code.
Any clue???
-Suganya
