hkurt
Mar 11, 2004 12:58 AM UTC
Assembler ST7 Visual Debug
Posted on March 11, 2004 at 01:58
hkurt
hkurtAuthor
Mar 10, 2004 3:14 AM UTC
Posted on March 10, 2004 at 04:14
I have defind:
MOTOROLA
RAM1: SET1 DS.W 1
RAM0: END_RAM0 EQU $1E
the following statement should get the Index for read the high byte of
SET1 in a subroutine.
CODE:
ld Y,#{SET1-END_RAM0} ;{} = Index, 8-Bit
ASM-Message:
Error 54: Can't match Addressing mode 'ld Y,#{SET1-END_RAM0} ;'
Subroutine:
sub A,({END_RAM0+1},Y) ;8-Bit-Addr.(=$1f) + 8-Bit-Offset
this line is correct in ASM Subr. obj-code is 90 E0 00
can sombody help me?
regars
Kurt
kr_it
Hi Habluetzel,
With the following declarations,
segment byte at 80-FF 'ram0'
.SET1 DS.W 1
.END_RAM0 EQU $1E
and with the same instruction
my assembler does not producing any error. I think there is a declaration error in your program. I could not clearly understand what is RAM1: & RAM0: in your code.
Could you reply?
--Krsel
