n_minakata
Apr 20, 2026 10:55 AM UTC
Are TSV321RAILT & TSV321RILT pin configurations exactly the same?
Are the pin configurations for TSV321RAILT and TSV321RILT exactly the same?
I'm having trouble finding this information in the datasheet.
Peter BENSCH
Peter BENSCHBest answer
Apr 20, 2026 11:12 AM UTC
Welcome @n_minakata, to the community!
The two order designations differ exclusively in the offset voltage, which is indicated by the inserted letter 'A'. The offset values are given in the data sheet, table 3 for VCC=3V and table 4 for VCC=5V.
The pin assignment is exactly identical for both.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
n_minakata
Apr 21, 2026 1:02 AM UTC
I understand perfectly.
Thank you for your prompt reply.
