Vivi
Jun 12, 2023 12:17 PM UTC
any different of EOLed ST72F561J9TBXS vs ST72F561J9TAS? any replacement MPN?
Temperature range A = -40 °C to 85 °C and C = -40 °C to 125 °C
but ST72F561J9TBXS Datasheet not mentioned suffix B temperature range, could you please share? thanks!
Peter BENSCH
Jun 12, 2023 1:36 PM UTC
Welcome, @Vivian Wang​, to the community!
these particular microcontrollers were discontinued a long time ago, but were also not generally available, as they were custom devices that only the specific customer had documentation on.
There are also no substitutes for these devices.
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
/Peter
Vivi
ViviAuthor
Jun 12, 2023 3:23 PM UTC
Hi Peter, regarding ST72F561J9TAS suffix A means Temperature range A = -40 °C to 85 °C and C = -40 °C to 125 °C how about ST72F561J9TBXS ? Datasheet not mentioned suffix B temperature range, could you please share? thanks!
Peter BENSCH
Jun 12, 2023 3:28 PM UTC
When a device is obsolete, I no longer have any support or documentation at all.
Sorry for not being able to help you in this case.
Regards,
/Peter
