y_gudekar
May 29, 2006 10:32 AM UTC
any c++ & RTOS Support for ST7?
Posted on May 29, 2006 at 12:32
y_gudekar
y_gudekarAuthor
May 8, 2006 10:55 AM UTC
Posted on May 08, 2006 at 12:55
Is there any cross-compiler available, which supports C++ for ST7?
Is there any RTOS support available for ST7?
Regards,
Yogesh & Amit
mjg21cn
May 25, 2006 8:44 PM UTC
Posted on May 25, 2006 at 22:44
i also want ask such a question.i
alain2399
For the C++ C compiler, even if you find one I do not see any benefit from using C++ on an MCU such as the ST7.
For the RTOS I would recomend µC-OSII which is quite cheap (you just have tu buy the book with the sources) and there has been a port to ST72 eventhough it is not on the Micrium web page dedicated to ST (
http://www.ucos-ii.com
