neil2399
Aug 2, 2006 12:55 PM UTC
Align variables
Posted on August 02, 2006 at 14:55
Align variables
neil2399
neil2399Author
Aug 2, 2006 9:49 AM UTC
Posted on August 02, 2006 at 11:49
Hi.
I'm using CrossStudio and a STR712F12.
I'm trying to get my variables to align to 16 bit addresses, i.e. align = 2.
I've created a new memory segment in my memory map and created new program sections under that. Each program section is then allocated a specific address and size in on-chip RAM.
All the variables that I want in those memory locations are then defined in a single .h file.
Like so:
#ifdef _PARAMETERS_
#define _SCOPEP_ __attribute__ ((section(''.parameters'')))
#else
#define _SCOPEP_ extern __attribute__ ((section(''.parameters'')))
#endif
_SCOPEP_ int overflow_count;
_SCOPEP_ int processor_idle;
etc.
Now, I also need those variables to align to 16bits.
I've tried changing the ''Alignment'' option for my program sections to ''2'', but it didn't do what I wanted.
Any help would be appreciated.
Neil
sjo
Aug 2, 2006 12:25 PM UTC
Posted on August 02, 2006 at 14:25
use the __attribute__ ((aligned (2))) option.
sjo
neil2399
neil2399Author
Hi sjo.
I've already tried that, but it doesn't work either.
I get no errors or warnings, but my variables remain aligned to 4.
Neil
