mikeh3
Sep 12, 2005 5:34 PM UTC
ADC noise issue
Posted on September 12, 2005 at 19:34
ADC noise issue
tod_02
May 17, 2011 10:06 AM UTC
Posted on May 17, 2011 at 12:06
Are you putting the MCU into idle mode (via PCON) when doing your A/D read? I noticed I got much better results when doing it this way.
francescatodiego2
Sorry cannot help you
I am starting new project wit uPSD and analog peripheral.
I see a lot of questions about ADC peripheral and I think is not good idea use it.
Before add one external ADC to my uPSD I ask you if you have solved the ADC problems ?
thanks
mikeh3
mikeh3Author
We are currently developing 10+ products with the uPSD33XX family of parts.
We have noticed significant A/D noise on all of the designs (7-10 Lsb's in most cases), this seems to be caused by some type of charge coupling from the A/D inputs (?)
Can anyone tell me what the recommended input impedence and/or input capacitance should be to minimize this problem?
We deal primarily with slow signals (10-100Hz)
We do many analog designs and are aware of most issues relating to good design practice - the microprocessors we have been using did not exhibit this problem.
Thanks in advance for any help given.
