sab964
Jun 8, 2006 10:33 AM UTC
ADC connections if not used, RTC VBATT connection
Posted on June 08, 2006 at 12:33
sab964
sab964Author
May 17, 2011 7:30 AM UTC
Posted on May 17, 2011 at 09:30
I'm working on a design with the 128 pin STR912FW44X6.
I don't need to use the internal ADC(but I want to use GPIO Port 4 as general purpose I/Os). Are there any recommendations for connections to the pins AVSS, AVDD and AVREF ?
I want to use the RTC but don't need to supply power to the RTC Unit when
the main digital supplies (VDD and VDDQ) are switched off. Can I tie VBATT to GND oder are there other recommendations ?
Thank you in advance,
Sascha
anis
Hi Sascha,
Please find the answers to your questions:
1- connect the AVDD, AVREF to VDDQ and AVSS to VSS
2- When not using battery for RTC, please connect the VBATT pin to VDDQ (do not connect to ground).
Best Regards,
STARM
anis
Hi Sascha,
I don't have the correct answer right now, I will ask and I will let you know rapidly.
Best regards,
STARM ;)
sab964
sab964Author
Thank you very much!
