Brian1
Aug 1, 2018 2:27 PM UTC
ADC Channel Measurement Using Internal Reference
Is it possible to use the ADC to measure the voltage on an external pin and use the internal reference at the same time? I have a product that is direct connected to battery, so my external reference voltage is variable. I'd like to use an external channel to measure a voltage, but use the internal reference. Are there any examples that exist for this?
    Aug 2, 2018 4:12 PM UTC
    In simplest form you can use this formula: Vrin = Vref * Dain / Dref , where Vrin - real input voltage, Vref - known voltage of reference source, Dain - conversion result of analog input , Dref - conversion result of reference source voltage.
