babidesai123
Aug 8, 2003 12:38 PM UTC
access port B as GPIO
Posted on August 08, 2003 at 14:38
chris_baragnon
May 17, 2011 9:55 AM UTC
Posted on May 17, 2011 at 11:55
hi,
yes you can access to port B in GPIO mode. Configure it in PSDSoft and you have to set correct value in direction and drive registers. You can write and read in port B by the DATA_IN or DATA_OUT register but
you can't access by bit
totof
babidesai123
i want to know the address of port B . Can i use the PB as GPIO pins?
Waiting for reply
Purvi
joseph2399
The address for DATAIN_B is: PSD_REG_BASE + 02
DATAOUT_B: PSD_REG_BASE + 05
DIRECTION_B: PSD_REG_BASE + 07
DRIVE_B: PSD_REG_BASE + 09
CONTROL_B: PSD_REG_BASE + 03
