Lee Young Jun
Mar 5, 2018 8:37 AM UTC
ABS(X) function in STM8S Library
Posted on March 05, 2018 at 09:37
Hello, I'm STM8S user.
I doing find the STM8S math.h, math.s in stm8s code example.. But i dont find it,,
I want to use ABS(X) ,, ABS(X) isnt there in math.h?
    Tilen MAJERLE
    Mar 5, 2018 9:27 AM UTC
    Posted on March 05, 2018 at 10:27
    Hello
    if you cannot find ABS function, you can make your own:
    #define ABS(x) ((x) > 0 ? (x) : -(x))�?
    Best regards,
    Tilen
    Philipp Krause
    Senior II
    Mar 5, 2018 10:47 AM UTC
    Posted on March 05, 2018 at 11:47
    I guess you want to use abs(). The name is in lower-case, and it is in stdlib.h.
    Philipp
    P.S.: However, if you want to handle floating-point numbers, you should use fabsf(), which is in math.h. Variants for different types exist both for integer (labs(), llabs()) and floating-point (fabs(), fabsl(), but those don't matter on STM8 as no current compiler supports double or long double).
