zues
Oct 31, 2005 4:29 AM UTC
Aboutu PSD3354 SRAM and Second Flashrom map address overlap
Posted on October 31, 2005 at 05:29
sunsy
May 17, 2011 10:08 AM UTC
Posted on May 17, 2011 at 12:08
Before firstly, you must make sure wether the SRAM/CSIOP and CSBOOT is in data space or not?
the sentence you write was access the XDATA in the data space.
if your SRAM/CSIOP and CSBOOT are both in data space, then their address is overlapped. you can only access the SRAM/CSIOP instaed the CSBOOT, in other words, the CSBOOT is transparent, never be accessed.
zues
zuesAuthor
Dear All:
memory map :
0000--7FFF ----->RAM and csiop
0000--7FFF ----->second flashrom csboot0~3
if following this code(in the main flasherom) --->
''*((volatile unsigned char xdata *)(0x6000))=0x34''
it access SRAM or Second flahrom?
if this code access SRAM,how can access second flashrom(if use VM and VM value set what)?
Best Regard!
Zues
