ss_it
Mar 7, 2008 12:58 PM UTC
about emi wait state setting
Posted on March 07, 2008 at 13:58
ss_it
ss_itAuthor
Mar 7, 2008 2:08 AM UTC
Posted on March 07, 2008 at 03:08
Hi
I use STR710.
When I use 48Mhz(Main Clock) with EMI_WAITSTATE(10), muc works very well.
But I changed Main clock to 32Mhz, also EMI_WAITSTATE(10), but MCU could not boot even if we change form CS0 to CS3.
How can I find EMI_WAITSTATE value ?
Is there any formula ?
Thank you
avelez
Mar 7, 2008 2:53 AM UTC
Posted on March 07, 2008 at 03:53
It depends on MCLK. If you low the clock on a 25%, I suppose you should increment the wait state in a 25%, so I'll consider a value of 13.
However, you'll get the best value though a trial-error procedure :-]
kleshov
Even better, consult the timing sections of the datasheets involved. And use an oscilloscope to verify that the required access cycle timings are satisfied.
