Jul 9, 2026 12:44 PM UTC
A simple question about x-cube-stse01 stsafea_verify_entity_signature() function
Hello everyone,
stse_ReturnCode_t stsafea_verify_entity_signature(
    stse_Handler_t *pSTSE,
    PLAT_UI8 slot_number,
    stse_ecc_key_type_t key_type,
    PLAT_UI8 *pSignature,
    PLAT_UI8 *pSignature_validity)
this is the declaration of the function, my question is:
against which hash/payload does the function verify the signature?
Thanks,
Giorgio.
Aug 21, 2026 9:50 AM UTC
Hi ​@bonafrect ,
This function is part of the Entity Authentication procedure which use the Generate Challenge to generate a challenge and verify the signature over this challenge. Therefore you don’t need to provide the hash for this command.
If you want to use the STSAFE-A as a crypto coprocessor to verify ECDSA signature, you need to use the stsafea_ecc_verify_signature() function
Best Regards,
Benjamin
