2N2907AHR Spice Model
Good Morning,
I downloaded the zip file for the 2N2907AHR SPICE model, but Windows complains that the folder is empty and cannot be extracted. Can someone else confirm this behavior, and if so would it be possible to post a working copy?
Thank you,
Jon
Peter BENSCH
Peter BENSCHBest answer
Welcome @longjonsilver24, to the community!
I'm very sorry for this mistake: it's not a zip, you just need to rename the .zip to .lib so that SPICE can work with it.
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
Yes that worked, thank you!
