X-CUBE-MEMS1 PresenceDetection configuration on STEVAL-MKI109V3
I am looking to set up the STHS34PF80 on the STEVAL-MKI109V3 board. I have tried configuring the PresenceDetection mems application. I measured 0 current on jumper 13 and no voltage on STHS34PF80. Are there any tips or suggestions for setting up the STHS34PF80 mems sensor on the MKI109V3 eval board?
Federica Bossi
Hi @jkutteh ,
Welcome to ST Community!
Can you share with me a picture of your connections?
PIN13 is GND that's why you don't see any voltage. Vdd is on PIN1.
