lowpowermcu
Where can I find fw filters of LPS331AP?
Posted on November 19, 2012 at 16:27
I want to build an altimeter using LPS331AP sensor and after reading AN4159 I discovered that I should have software filter to have an accuracy of 0.02 mB required for altimetery.
Do you know where to download such filters?
MCU L�fter
#lps331ap
    ilyinyury
    February 22, 2013
    Posted on February 22, 2013 at 04:02
    Hi.
    I got the same problem. I found how to get TCV1, TCV2 etc, but still can't calculate correctly pressure correction values. I want to use this sensor for my weather station project, but found that pressure variation over temperature change is too high, especially at minus temperature. e.g: -10C => 1001hPa, -16C => 1002.3hPa with the same actual pressure.
    It's very strange what software filter is not available through this website; it was mentioned in AN4159, but even registers addresses are not mentioned any available documents.
    Does anyone have such information? Can share please?
    Yury.
