Nathalie MAGNIEZ
When the LIS3DH FIFO is enabled, reading 6-byte data registers again and again will make the FIFO pop data automatically. How about only reading three high bytes OUT_X_H, OUT_Y_H and OUT_Z_H?
Posted on September 07, 2013 at 18:05
#motion-sensor #fifo #accelerometer #lis3dh
Thiago REIS
Posted on September 09, 2013 at 17:39
Hello Naue,
Yes, it works the same way as reading 6-byte data registers when only reading three high bytes it does not no matter if LIS3DH is in normal mode and low power mode.
For more information, please check the attached detail sheet and visit www.st.com/mems
Thank you,
Thiago Reis
Posted: Saturday, September 07, 2013 6:05 PM
Subject: When the LIS3DH FIFO is enabled, reading 6-byte data registers again and again will make the FIFO pop data automatically. How about only reading three high bytes OUT_X_H, OUT_Y_H and OUT_Z_H?
________________
Attachments :
LIS3DH.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzKb&d=%2Fa%2F0X0000000bJy%2FQEsXyCUBUbfRTMipW.orh7OKoL9fN49r36jEy4BPBXU&asPdf=false
