Evelina CAMILLERI
Jul 15, 2021 8:32 AM UTC
When should I use the MLC function and when should I use the CARTESIAM AI software solution?
    Evelina CAMILLERI
    Jul 16, 2021 3:04 AM UTC
    You can use Cartesiam software solution if you want to run AI at MCU level while you can use MLC if you want to run AI at sensor level. The choice can be made based on the current consumption requirements of the node and the AI model that the user wants to implement.
    Evelina CAMILLERI
    Evelina CAMILLERIAuthorBest answer
