Dennis Dang
May 25, 2018
What is the recommended 6+3 solution equivalent to LSM9DS1 in wearable product?
Posted on May 25, 2018 at 15:25
Greetings,
Currently in our wearable product we are using LSM9DS1 to get the 9-axis sensor fusion result which is quite good (interruption rate set to 238Hz).
However we'd like to use a 6+3 solution to reduce the cost. Is there any recommendation on 6+3 solution to get a good 9-axis sensor fusion result?
Thanks a lot.
Thanks,
Dennis
Posted on May 25, 2018 at 15:54
I would recommend you combination of LSM6DSL + LIS2MDL.
