JSand.4
Jun 3, 2021 8:23 AM UTC
What is the noise density for LIS344ALH, when in 6 g mode? In 2 g mode the noise density is Typ 50 ug/SQRoot(Hz). Is the noise density 3 times higher in 6g mode?
niccolò
niccolòBest answer
Jun 8, 2021 3:17 PM UTC
Hi @Community member​ ,
the noise density at 6g is typically a little higher than the one at 2g.
as per my experience I'd say it is 20% higher.
if you need an exact value you can try to calculate and characterize your sensor.
hope this helps
Niccolò
p.s. if you found a solution to your problem, please, select a best answer to help other users with similar issues
niccolò
niccolòBest answer
hope this helps
Niccolò
JSand.4
JSand.4Author
Jun 9, 2021 10:34 AM UTC
Hi Niccolo,
Thank a lot for your answer. It was very helpful!
Best Regards
Jesper
