Pascal Wielsch
What is the difference between the "LIS2DH12TR" and the "IIS2DHTR"?
Hello there,
can anyone tell me the difference between these both MEMS accelerometers? Based on the data sheet, it seems that both sensors are identical.
Thanks in advance!
Best Regards,
Pascal
Petr S
Usually the industrial sensors are more strictly tested, they may have more min/max values in datasheet and don't have to support all the functionalities. But as far as the ASIC is the same you can communicate with both sensors identically.
