Evelina CAMILLERI
Nov 11, 2022 1:57 PM UTC
What is the difference between ST ISM330ISN and the SOX range ?
    Luca SEGHIZZI
    Luca SEGHIZZIBest answer
    Senior
    Nov 11, 2022 2:20 PM UTC
    The difference is that the DSOX has a machine learning core based only on decision tree, it is limited
    but highly efficient and it is a plug & play solution.
    An ISPU device can be customizable with whatever ML algorithm you want to implement using C codes or NEAI studio which will find by itself the best library for the anomaly detection
    Luca SEGHIZZI
    Senior
