DChou.2
Aug 1, 2022 6:08 AM UTC
What is IIS2ICLX accuracy and resolution?
Can IIS2ICLX able to provide 3 Min of arc Accuracy and resolution? My application need 3 Min of arc accuracy and 1 min of arc resolution, is IIS2ICLX sensor capable to provide that with calibration?
*Edited by moderation, please keep the title of your question shorter than 70 characters*
    Eleon BORLINI
    Aug 5, 2022 11:06 AM UTC
    Hi @DChou.2​ ,
    I'm not sure you can get the 0.05deg resolution (since the resolution also depends on the tilt angle itself), but I suggest you to check this DT0140 Design tip which describes the tilt computation using accelerometer data for inclinometer applications involving IIS2ICLX device.
    -Eleon
