TJM
Senior II
May 24, 2021 3:10 PM UTC
Webinar Info: Using the Data Logging Capabilities of an ST Industrial Sensors Development Kit
Good morning. This would be for an ST employee, please.
If possible, I would like to contact the group responsible for the Sensor webinar coming up in a week or so. I'm looking to find out if there is any support information that I can get before the actual webinar takes place. One of the specific items would be which project download will be used. There appears to be two downloads with conflicting version numbers: en.fp-sns-datalog1.zip and en.stsw-stwinkt01.zip . Also, and if not already planned, it would be nice to see each module (BLE, Serial and WiFi) working as they should, up front and with the ST BLE Sensor app. I can successfully recompile and install each module, connect only with the phone, and can't get any data to transmit to wifi, BLE, file or Watson.  I've been through all of the briefs and user manual but I'm overlooking something and I'd like to find out what that is before the webinar.
Thanks,
TJM
    TJM
    TJMBest answer
    Senior II
    May 26, 2021 2:22 PM UTC
    Eleon, that is the webinar and thanks for the instructor info. And, I 've been able to get both sensor development kits workings as they should.
    TJM
    Eleon BORLINI
    May 26, 2021 12:23 PM UTC
    Hi @TJM​ ,
    I would suggest you to prepare your specific question for the day of the webinar, and send it to the webinars' referents.
    By the way, are you referring to this webinar, right?
    If so, I see that one of the instructors is @Ernesto Manuel CANTONE​ ​: you might contact him in the message section and ask your question.
    -Eleon
    TJM
    TJMAuthorBest answer
    Senior II
    TJM
    Eleon BORLINI
    May 26, 2021 2:24 PM UTC
    That's good @TJM​  :)
