ARaj.3
December 1, 2020
We are trying to integrate LIS2DTW12TR / STEVAL-MKI190v1 with our SoC/SDK, and we are trying to follow https://github.com/STMicroelectronics/STMems_Standard_C_drivers.git and integrate sensor with our code base.
  • Not able to see x, y axes changing, only Z axis is changing.
  • Activity module too is not working.
Any pointers?
Eleon BORLINI
Hi @ARaj.3​ ,
which is the code you are using? The lis2dtw12_read_data_polling.c for the data acquisition and the lis2dtw12_activity.c for the embedded activity configuration? And are you able for example to read the correct WHO_AM_I register content (as starting point)?
And a last question: do you use I2C or SPI for the communication with your application processor?
-Eleon
