Manuel Göb
May 7, 2018
VL6180X setting for specular/glossy reflecting targets?
Posted on May 07, 2018 at 12:05
I have to perform some distance measurements in a system of stainless steel pipes. The VL6180X sensor I am using so far gives me values about 10mm below the true distance value.
My assumption is that the non-diffuse reflecting behaviour of the stainless steel causes the wrong values. Are there some settings I can do to measure distances to glossy targets (e.g. setting some registers)?
Thank you in advance,
Manuel
#vl6180x #vl6180 #specular #glossy #mirror
