LBahn.1
May 16, 2022
VL6180X and VL53L0X (Pololu) reliably sense to 0.5 to 1mm. Goal: sense changes to 0.001inch / 0.025mm for measuring table movement of small lathes/mills.
Is there a TOF sensor product / software solution that can obtain 0.001inch measurement precision?
Thanks in advance.
John E KVAM
A round trip of 1mm uses 6.7 pico seconds. And a pico second as you know is one millionth of one millionth of a second. And the vl53 sensors are only a few dollars.
As much as I'd love the sensor to have accuracy that good, it just isn't going to work.
I'm afraid for your application a dial indicator is still the best way to go.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
