adi-mistrzu
VL53L1x - gesture recognition
Posted on April 26, 2018 at 08:11
Anyone know how to config VL53L1x to gesture recognition?
In datasheet is information about support 1D
gesture recognition, but nowere I cannot find information how to config it to gesture recognition and how to use it.
I check your API for this sensor, but there no code for gesture recognition.
Anyone know how to do that?
Best regards
#recognition #api #gesture #vl51l1x
John E KVAM
Posted on May 02, 2018 at 00:39
There is no 'gesture recognition' mode by itself. The concept relies on simply ranging and looking for a changing distance result. It's up to the use to interpret the distance measurements and decide what the gesture is.
One way is to range with a threshold. Your CPU can be asleep. When a hand comes close, the sensor will wake your processor and you can start looking at the data. Interpret the gesture based on what the distance and signal strength data is telling you.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
