Josh Yu
Mar 24, 2018 1:24 PM UTC
VL53L0X Calibration Target - What to use?
Posted on March 24, 2018 at 14:24
The user manual mentions using one 88% reflectance target and 17% reflectance target for calibration. I don't know what material has those reflectance values. What exactly should I use for calibration and where can I get those?
John E KVAM
John E KVAMBest answer
May 7, 2018 11:26 PM UTC
Posted on May 08, 2018 at 01:26
It’s called Munsell Color Paper
X-rite Inc
4300 44th street S.E.
Grand Rapids, Mi 49512
Tel 877-888-1720
The stuff is expensive. Like $26 per sheet expensive.
We use 5%, 17%, 42% and 88% reflectances in our testing. One color per sheet.
MUNSEL NOTATION N2.75/
STM275MA4
5% REFLECTANCE
STMN475/MA4
17% REFLECTANCE
STMN95/MA4
88% REFLECTANCE
STMN675/MA4
42% REFLECTANCE
But standard Photo grade white paper is close enough to 88%, that it will work unless you are really particular.
Black spray paint is 5% reflective. Use a couple of coats. Doesn't matter if it's flat or gloss.
I don't have a good source of 17% gray.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
Mar 24, 2018 9:07 PM UTC
Posted on March 24, 2018 at 22:07
Have a look at this lecture presentation:
https://www.cs.cmu.edu/afs/cs/academic/class/15462-f09/www/lec/lec8.pdf
Also, Wikipedia offers quite good explanation:
https://en.wikipedia.org/wiki/Reflectance
However, I wasn't able to find some online trustworthy database of reflectance of various materials.
David
Josh Yu
Josh YuAuthor
Mar 25, 2018 5:25 AM UTC
Posted on March 25, 2018 at 05:25
Thanks David! The two links you posted explained what reflectance is pretty well. It sounds like the white target is probably something opaque and with a smooth surface finish. And the dark target is probably something with a rougher finish?
I found this chart on Google. I don't know how trustworthy this is but I thought it was interesting enough.
https://www.automation.com/images/uploaded/chart1.bmp
Josh Yu
Josh YuAuthor
Mar 26, 2018 3:46 AM UTC
Posted on March 26, 2018 at 05:46
I've found this sentence from the VL53L0X datasheet (under 'Performance' -> 'Measurement Conditions'):
Reflectance targets are standard ones (Grey 17% N4.74 and White 88% N9.5 Munsell charts).
So it seems like the targets are Munsell color cards. Now the problem becomes how to get those color cards... A quick search online only reveals small pocket sized color cards, which is probably not big enough...
John E KVAM
X-rite Inc
Tel 877-888-1720
STM275MA4
5% REFLECTANCE
STMN475/MA4
17% REFLECTANCE
STMN95/MA4
88% REFLECTANCE
STMN675/MA4
42% REFLECTANCE
