MSAMB.1
VL53L0X CALIBRATION
Hello, I am writing this message to you because I need help, if it is possible I would be grateful to you .. Ok, I am working on a project in which we will use the VL53L0X as a sensor in an access control device , we will use it as a proximity sensor to trigger the opening of a door .. For this I bought a P-NUCLEO- 53L0A1 board to perform tests with the his VL53L0X sensor, I performed distance tests, air gap tests manually and read the values.
However in the UM2039 manual I saw that there are several calibration tests to be performed except that I did not do very well in software I downloaded the eclipse software import the VL53L0X file from the API but I don't know where to start or how to start my calibrations, what code to use etc if you have any leads it would really help me to move forward ..
Thanks .
