MSAMB.1
VL53L0X
What is the difference between signle and continuous mode ? someone can telle me please the real difference I'm using the VL53L0X
Peter BENSCH
You probably mean the single and continouos ranging, right?
The datasheet provides quite detailed information:
Single ranging
Ranging is performed only once after the API function is called.
System returns to SW standby automatically.
Continuous ranging
Ranging is performed in a continuous way after the API function is called. As soon as the measurement is finished, another one is started without delay.
User has to stop the ranging to return to SW standby. The last measurement is completed before stopping.
Does it answer your question?
/Peter
