ee06091
VL53L0 - How it works
Posted on March 08, 2016 at 15:40
Do you have any plans to release a version of this sensor with a smaller FieldOfView?
As your presentation note you use a kind of diode matrix as photon input, do you plan to output the data of each diode to identify where the obstacle is?
Per example at 2 meters with a 25degree FOV the obstacle could be anywhere inside a 0.44 meters radius circle. Is is good for obstacle detection but not for obstacle avoidance because a robot with 0.5 meters diameter can't move on a 0.7 meters passage because it will detect walls.
#vl53l0
Julien NGUYEN
Posted on March 19, 2016 at 01:35
Thank you for your comment. I can not tell you about our roadmap. You may contact marketing people in charge of the ToF sensor for that question.
