Vibration on the ISM330DHCX example or configuration using C driver
I just like to configure the ISM330DHCX for vibration measurement. Is that an example or a sample code(using its C driver ) of it somewhere. Please give me a pointer. Thanks.
Federica Bossi
Federica BossiBest answer
Hi @ttron ,
You can look at our official driver on Github.
Hope this helps :)
ttronAuthor
Let me expand on that: able to
1. Set a desire ODR
2. Set a threshold to wake up or trigger an interrupt (INT1). That's generate an interrupt if the acceleration above certain threshold (like > 10mg, etc).
3. Use stream FIFO
Andrew Neil
Federica Bossi
Hi @ttron ,
Hope this helps :)
