Evelina CAMILLERI
Jul 15, 2021 8:16 AM UTC
To train the MLC Decision tree, can the training dataset be generated based on simulation?
    Evelina CAMILLERI
    Jul 15, 2021 8:17 AM UTC
    Training a sensor using generated data can be tricky because your generation program needs to mimic as much as possible the sensor behavior (in terms of output data rate, full scale, sensitivity, noise, etc...). If, ideally, you have a good sensor model that can emulate the physical sensor, using simulated training data for the MLC is possible.
    Evelina CAMILLERI
    Evelina CAMILLERIAuthorBest answer
