The power consumption of LIS2MDL in power-down mode
Hi,everyone.
I measured the power consumption of LIS2MDLTR on the same board in power-down mode.
and found that the LIS2MDL chip on STEVAL-MKI217V1(from mouser) consumes less power than the LIS2MDL purchased separately from mouser.
We have some question and need your help.
  1. ​ What is the power consumption LIS2MDL in power-down mode ?
  2.  Why do the parameter differ between LIS2MDL chip on STEVAL-MKI217V1 and LIS2MDL purchased separately?
Federica Bossi
Federica BossiBest answer
Hi @young ,
The typical current consumption in PD mode is 1.5uA, as written in the datasheet.
How much difference did you measure between the two parts? It could be part-part variability.
Federica Bossi
Hi @young ,
youngAuthor
Hi,@Federica Bossi,
The consumption in PD mode that I measured is 70 ~ 80uA.
The power consumption of the component deviates significantly from the typical consumption.
Federica Bossi
Hi @young ,
How are you testing the LIS2MDL? There may be an error in your board design that is causing extra power consumption.
