Dor_RHBest answer
Jul 27, 2026 10:23 AM UTC
Hello ​@Profanity,
I recommend referring to the LSM303AGR integration available in STM32CubeF4: Link (here)
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Dor_RH
Dor_RHBest answer
Hello ​@Profanity,
Andrew Neil
Jul 27, 2026 10:30 AM UTC
As ​@Dor_RH said, have you tried ST’s provided example?
What hardware are you using?
The magnetometer doesn’t start over I2C
Have you checked hardware connections?
Correct pullups?
Correct slave address, and correctly presented in the software?
Have you used an oscilloscope and/or logic analyser to see what’s actually happening on the bus?
doesn’t output data via UART
The LSM303AGR doesn’t have a UART.
