Feb 21, 2025 7:58 AM UTC
Temperature accuracy LIS2DW12
Hi all,
Could you show me the temperature accuracy of LIS2DW12 ?
Thanks all,
Andrea VITALI
Andrea VITALIBest answer
Feb 21, 2025 4:59 PM UTC
Always look at the datasheet.
In your case: paragraph 2.3 table 5 clearly states +/-15deg offset. Which means you need to do 1-point calibration to get the correct absolute value: offset to be subtracted = temperature from the sensor - actual temperature.
Other parts have smaller offsets thanks to factory calibration.
Andrea VITALI
mecoAuthor
Feb 26, 2025 5:36 AM UTC
Thank you, Andrea
Are there any other datasheets available for the LIS2DW12 temperature sensor?
Andrea VITALI
Feb 26, 2025 4:56 PM UTC
the datasheet for LIS2DW12 is already online and there is no other datasheet
if you need an accurate environmental temperature sensor, check STTS75
mecoAuthor
Apr 30, 2025 7:44 AM UTC
Thank you, Andrea
Problem solved
