November 22, 2023
STHS34PF80 get image
Is it possible to get the raw image from STHS34PF80 sensor? And what is the resolution of this image in pixel. I would like to know if it's possible to to use this sensor to count how many people are in the field of the sensor.
Thanks,
Peter BENSCH
Peter BENSCHBest answer
Welcome @Tiphaine, to the community!
The STHS34PF80 is a sensor for presence and motion detection, it is not an image sensor whose image data could be read out as raw data. It is also not designed to count several people, you would probably have to use a real camera with subsequent image processing.
Does it answer your question?
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
