joe_electric
July 25, 2024
STHS34PF80 - Can interrupt generation be non-volatile programmed?
I would like the ability to generate an interrupt be programmed into the embedded flash so that I can use STHS34PF80 without a microcontroller. Is this possible?
Federica Bossi
Hi @joe_electric ,
STHS34PF80 has no embedded flash. You need a microcontroller to configure it, and then you can keep the microcontroller in sleep mode while the sensor is working.
