Aug 2, 2023 9:32 AM UTC
STEVAL-STWINKT1B is not connecting to wifi
Hello. I made all the adjustments for my STEVAL kit. I also installed the necessary binary file in the Wifi module (Dsh predmnt). According to the guide I gave in the link, I stay on page 12 step 8. When I enter the wifi id password, it does not connect. My wifi module just lights up yellow red. Can you help me why the problem is caused?
I installed the DSH-PREDMNT binary file only on the wifi module. I did not install it on the STEVAL kit. could the problem be caused by this?
niccolò
Aug 3, 2023 10:32 AM UTC
Hi @bcryhun ,
yes, you should first upload the STWIN with the FP-AI-PREDMNT2
then you can connect with wifi =)
If this answers your question, please, mark this as "best answer", by clicking on the "accept as solution" to help the other users of the community
Niccolò
bcryhunAuthor
Aug 6, 2023 10:48 AM UTC
it did not work. Clearly i am doing everything true. But when i try to write ssid and password of wifi, it does not respond. Documentation not clear.
niccolò
Aug 7, 2023 7:56 AM UTC
Hi @bcryhun ,
are you trying to run the example as it is?
how did  you uploaded the fw?
Niccolò
