David Wallén
Oct 14, 2020 1:30 PM UTC
SensorTile MEMS Audio stream to Unix-like OS (Raspbian)
I am exploring the SensorTile (STEVAL-STLKT01V1) and would like to capture Audio recordings on a Unix OS (namely Raspbian).
I have looked through the documentation here and the option to save audio to SD card is not ideal for my application, neither is reading from Windows.
I have gotten the AudioLoop demo software to run and capture sound on Windows, but was wondering if there is any documentation or clues as to how to get it set up on Raspbian?
The SensorTile is currently not getting recognized as a USB device in Raspbian, and before starting to hack away on my own I thought I'd ask the community if anyone has ever done this?
Thanks in advance!
Best Regards,
David
David Wallén
David WallénBest answer
Oct 14, 2020 2:41 PM UTC
Never mind this question. Seems that linux was detecting the audio streaming device just fine. I was using a bad USB cable...
For anyone wondering how audio stream could be accessed under unix it is very simple. The Audio stream can be read with pyaudio for example.
David Wallén
David WallénAuthorBest answer
