DDAng.1
Apr 18, 2021 8:37 PM UTC
SensorTile.Box - How can i interface the SensorTile.Box to a python script using BLE Connectivity on Windows 10
Hi! I'm struggling to get a BLE connection to my SensorTile.Box throught a Python script. I searched on internet and i found BlueST-SDK for Python. However, this is working just for Linux (as i read on Docs). I tried several time installing "Bluepy" and "BlueST" libraries using "pip instal -name-" command. As result, several errors occurred. What can i do? Is there any possibility to use it on Windows?
    Eleon BORLINI
    Eleon BORLINIBest answer
    Apr 19, 2021 12:56 PM UTC
    Hi @DDAng.1​ ,
    I'm afraid that there is only the Python code with Linux driver, at least as a package provided by ST (the one you found on Github).
    You could however try to ask there (I mean, on Github) if they can develop a code also for Windows, or if they can address you to the right code.
    There is the ST BLE Sensor app code for Android, that you could run on Windows with an Android emulator (such as Android Studio), but I believe you are not directly interested in this solution...
    -Eleon
    Eleon BORLINI
    Hi @DDAng.1​ ,
    -Eleon
