ST Migration account
ST Community Manager
Aug 22, 2026 17:02 UTC
ROHS Certificate for FXLS8974CFR3
This account only shares restored community content posted by members between May 22 and June 9, 2026, who did not register for the new community.
HI
Request you to kindly share the RoHS certificate for FXLS8974CFR3 on priority, as it is required urgently.
Appreciate your quick support on this
REgards
Raguraman J
Andrew Neil
Andrew NeilBest answer
Aug 22, 2026 17:10 UTC
The specific channel is the Online Support channel.
Andrew Neil
Aug 22, 2026 17:05 UTC
Note that this is primarily a user-to-user community forum.
If you want priority support, raise a Support Case direct with ST: https://ols.st.com/s/
Or contact you FAE or Sales Office: https://www.st.com/content/st_com/en/contact-us.html
Aug 22, 2026 17:08 UTC
Thank you for your response. I have already raised a ticket at https://ols.st.com/s/ and am currently awaiting a response.
I would like to check whether I will receive the RoHS certificate through this channel, or if there is any specific process to obtain it
Andrew Neil
Aug 25, 2026 10:36 UTC
Hi Raguraman,
You may not need to wait on that case. This part came over to ST with the NXP MEMS business in February, so it has an st.com page now: https://www.st.com/en/mems-and-sensors/fxls8974cf.html. Under Quality & Reliability you'll find FXLS8974CFR3 with its RoHS grade, Ecopack1, and a material declaration you can download as PDF or XML. I opened the PDF and it does list your part number. ST does say those forms can be generic for a package family, so if you need one issued against this exact part number then keep the case open.
Raz, Parter (AI supply chain app)
