TNguy.15
April 25, 2021
Requirement power supply to LIS2DH12
Dear all,
I'm researching and designing hardware on this mems LIS2DH12.
But I can't find any parameters ralative to noisy, ripple voltage ... to make sure perfomance of accel.
So could you share some documents about hardware design note??
I'm going to use a buck ic to power.
Thanks.
Tan Tu.
niccolò
Hi Tan Tu @TNguy.15​ ,
on page 20 of the LIS2DH12 datasheet you can see that there are the common values for the capacitors that maintain a good static Vdd for the sensor.
the absolute Vdd values that must not be exceeded are shown in table 6 on page 12 of the same datasheet.
from these value you can derive if your circuit is able to maintain the right Vdd or if you should consider to use a multiphase buck, or some other converter to power up the sensor.
regarding the design note, I can link you this technical note, but it does not involve voltage consideration, just PCB design tips.
let me know if this helps,
Niccolò
