Dinakaran Palani
Regarding PCM buffer data used in audio loop example of bluecoin
how can i store 1 second audio data using audio loop example
    niccolò
    Hi @Dinakaran Palani​ ,
    if you follow the datapath of the audio signal you will find the audio buffer.
    once you find it, you can store it in a long array until you have enough samples to make one second.
    hope this helps,
    Niccolò
    Dinakaran Palani
    Hi @niccolo.ruffini​
    how frequently should I capture the data from pcm buffer to another buffer
    the second one is how should I declare that buffer for storing one-second samples for the sampling rate 16000 for single-channel
    if I declare an array of uint16_t[16000] if I do so I am getting excessive use of ram
    niccolò
    you should capture data from the buffer every time it is full, otherwise you loose samples.
    do you get the error even if you use the malloc?
    Niccolò
    Dinakaran Palani
    how to do it
    niccolò
    you can follow this link to check how to use the malloc function.
    hope this helps
    Niccolò
    Dinakaran Palani
    i tried allocating by using the snippet as shown in the example link I am not able to allocate 16000 memory location
    niccolò
    What system are you using?
    Niccolò
