kSun.1
Qvar sensing - questions
I am very interested in this Qvar sensing.
  1. What i understand is this Qvar depends on the electrode discharge and the Qvar wants to take advantage of ESD, is it correct?
  2. Also does the Electrode sensing pad size affect sensing ability?
  3. How could we protect the pins/chip? Do we always need ESD Diode to protect the Chip ?
    Eleon BORLINI
    Hi @kSun.1​ ,
    I see your post also on this other post, thank you from ST for the appreciation.
    The ESD diode are mandatory to protect the QVAR lines from electrostatic and electromagnetic discharges that goes beyond the absolute maximum rating that the QVAR can withstand. The dimension of the electrode pad affects the "wireless" electric field sensing, while it is pretty negligible for the QVAR contact sensing.
    -Eleon
    kSun.1
    kSun.1Author
    Hi Eleon,
    Great, thanks a lot for replying. a few more questions to bother you:
    1. Is wireless electric field sensing based on electrostatic induction? while contact sensing is based on electrostatic discharging?
    2. I saw the eval kit STEVAL-MKI228KA, why the electrode designed in such way that Q+ and ground should be touched the same time?
    Eleon BORLINI
    Hi @kSun.1​ ,
    basically "yes" at both questions :)
    -Eleon
